willwoll100 0 Posted January 27, 2005 Can this be done without having to remove anything else? regards Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 27, 2005 I think so, nothing major anyways You will need some spline keys/sockets tho... Quote Share this post Link to post Share on other sites
willwoll100 0 Posted January 27, 2005 Ok cheers, wasn't sure about the radiator, whether it would have to be removed as well. I've got a spline socket set as I needed some to remove the drive shafts. Cheers Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted January 27, 2005 If you release the front engine mount and jack the engine up it gives a lot better access to the manifold bolts. Quote Share this post Link to post Share on other sites
gibber 0 Posted January 27, 2005 Make sure you take the bolt out off the dip stick or the bugger is a pain to get off! But it can easily be done with every thing in place, just a bit fiddly, watch ya knuckles on the fins of the rad when you undo them tight bolts! Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted January 27, 2005 no need to remove the rad but as said its tight! Quote Share this post Link to post Share on other sites
