A20 LEE
Best Engine builder?
Time to start planning for next year, got a mate selling a VR block which will be the perfect start for my new motor. Looking for the best company to overbore/hone it + balance it. Recommendations? Doesn't have to be a VW's specialist, just a cracking engineering shop. I'll handle the assembly myself. Also, what does blueprinting involve?
If its a VR engine, then i'd say get it down to Stealth Racing mate quite honestly. I don't think there is anything they can't do with VR6 engines there...
Another vote for Stealth and also Grant Motorsport.
Blue printing IIRC is the process of setting up an engine, removing casting imperfections, tightening tolerances, balancing etc etc. It was mainly done in the good old days when engines left the factory in a pretty rough state but these days engine tolerances are fine enough to not really require BP'ing.
Blueprinting properly also involves e.g. buying 9 pistons, and using the 6 that fit the bore tolerances best. The same applies to all the other components - buy twice as many as you need, and choose the best ones. Hugely expensive process, and like Kev says it's less important these days as factory tolerances are tighter than they used to be.
They can hone but over boring is subcontracted out.
Going for a 3.0 are you?
Don't know, i'd guess its no more expensive to go 3.1 or 3.2. Just at the planning stage and assembling "the list".
