maximus2029 0 Posted February 9, 2005 Hello, i had my rear brake pads and discs changed a few months ago,since then my abs light stays on.Any reason why?Please help Quote Share this post Link to post Share on other sites
VR6 0 Posted February 9, 2005 Sounds like the sensors ... Quote Share this post Link to post Share on other sites
Henny 0 Posted February 10, 2005 the place which changed your rear disks either hasn't put the ABS cages back on, or hasn't replaced them with new ones. This means that they will not be spinning with the disks properly so the ABS brain doesn't know how fast the wheel is spinning and so puts up a fault light. Take it back and tell them to sort it if you got it done at a garage. ;) You may have to buy some new cages (the bit which sits on the back of the disk) but they're only £10 per side... 8) Quote Share this post Link to post Share on other sites
