fla 9 Posted February 14, 2005 I posted a thread sometime back called "hissing when getting hot". Basically when the temp would hit about 108C there was a wheezing-type noise as the fans tripped in. Turns out that this is the same noise when I turn the a/c on (norm not max) with the engine off. The system needs to be regassed but all you privileged lot with a/c does this also happen to you too? And should the flap movement cause a hiss? Why does it move anyway when the cooling fans trip in? Thanks Share this post Link to post Share on other sites
VR6 0 Posted February 14, 2005 I've moved it from the archive so that you can begin where you left off. http://the-corrado.net/.archive/forum/viewtopic. ... highlight= Share this post Link to post Share on other sites
