stel g60 0 Posted February 18, 2005 hi guys, has anyone got the part number for the 3.5 bar fuel regulator for the g60? euros is only round the corner so i wanna go get 1 and fit it today. muchos appreciatos Stel Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted February 18, 2005 Why do you need a 3.5 bar regulator??? Quote Share this post Link to post Share on other sites
stel g60 0 Posted February 18, 2005 the car seems like it needs more fuel since i fitted the red injectors, rallye cooler and 65mm pulley. it has got good pressure but seeing as its got an sns chip from pitstop i think the regulator will benefit the engine Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted February 18, 2005 I run exactly the same setup bar a different intercooler and I've not needed a 3.5 bar regulator. As long as it's all setup correctly you shouldn't need one to be honest. Depends on if your regulator has had it or not. You'll probably find with a 3.5 you'll end up overfuelling. Call Steve at pitstop and ask his advice before you buy one if I was you. Quote Share this post Link to post Share on other sites
stel g60 0 Posted February 18, 2005 Call Steve at pitstop and ask his advice before you buy one if I was you yeah, i just did that and he said exactly the same thing you did so ill be scrapping that idea. cheers for the advice anyway joe. Quote Share this post Link to post Share on other sites
golfg60 0 Posted February 18, 2005 What circumstances would you need one then, i thought (obviously incorrectly) that a smaller pulley, red tops and a staged charger would warrant the use of one? Quote Share this post Link to post Share on other sites
Henny 0 Posted February 18, 2005 it depends on the generation of SNS chip you have... the earlier ones were written to use the 3.5bar FPR, the newer ones don't need it so you should stay with the stock 3bar FPR... Quote Share this post Link to post Share on other sites
stel g60 0 Posted February 18, 2005 it depends on the generation of SNS chip you have... the earlier ones were written to use the 3.5bar FPR, the newer ones don't need it so you should stay with the stock 3bar FPR... henny you are quite right. according to steve i got the later chip which is why he didnt fit the regulator in the first place. you know, i luv this forum, if it wasnt for you lot id still be getting nowhere with jabbapoop! Quote Share this post Link to post Share on other sites
