billinjah
caliper wind back tool
For what its worth, there was a tread on here some while back..
stand by.......................................
Could i make one easily enough or is buying the only solution?
Long bolt with a 17mm head and a nut same size with some big washers has done the job for me on numerous occasions.
Screw the nut pretty far down the bolt then put the washers on, put the bolt head on the piston, wind back the nut till the washers are pressing on the caliper then hold the nut with one spanner and turn the bolt head clockwise with the other. This piston will turn with the bolt once its under a bit of load.
