Bournemouth James 0 Posted June 19, 2003 Is it a big job to convert a g60 to take 5 stud wheels? Is there a hub conversion kit you can buy or something? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted June 19, 2003 VR6 Rear axel Job done (i would think) fronts!! late g60 with face lift may be but the shafts may be different Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted June 19, 2003 VR6 Rear axel Job done (i would think) fronts!! late g60 with face lift may be but the shafts may be different I thought all g60s were 4 stud (including late ones), am I wrong? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted June 19, 2003 VR6 Rear axel Job done (i would think) fronts!! late g60 with face lift may be but the shafts may be different I thought all g60s were 4 stud (including late ones), am I wrong? sorry let me fill in the caps all G60 are originally 4 studs. the face lifted G60's share suspension component with the VR6 so a swap may be possible, including brakes etc. but the drive shafts may not fit as they will be a different length so you may have to put Vr ones in. someone must have tried it!! Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted June 19, 2003 Fit 5-stud rear disks (straight swap) and that's the rear sorted. At the front, fit the complete wheel bearing with mounting parts - although it may be possible to just fit the wheel hub (part numbers appear to be identical it's just that they seem to come in 4 and 5-stud varieties. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 19, 2003 i have some vr hubs should anyone need a set as i was gonna do exactly this conversion... Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted June 26, 2003 Does any one know of a kit? Quote Share this post Link to post Share on other sites
Valver 0 Posted June 27, 2003 I think you can buy H&R adapter kit to go from 4x100 to 5x100. HTH Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted June 27, 2003 Cool, where do I get it from? Quote Share this post Link to post Share on other sites
dav 0 Posted June 27, 2003 Bournemouth James, "eurospecsport" also do a kit, that converts 4x100 to 5x100, i think that they are about £75 each or the pair. Nearly bought some from last years GTI international good quality too. you can find them on the net. Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted June 27, 2003 found them but there doesnt appear to be any dealers in the uk Quote Share this post Link to post Share on other sites
