olly elworthy 0 Posted February 28, 2005 any of you know if i can connect a 5 wire wideband sensor to a normal air fuel gauge? or will they only work with a lm-1 or similar instrument? as im thinking of instaling one soley to run my air/fuel gauge if so where do the wires go and what do they do? i.e for a four wire sensor, 1 ground 2 heater, 3 to ecu/gauge 4 switched live, :D Quote Share this post Link to post Share on other sites
stevemac 0 Posted March 2, 2005 Have a chat with Daz (g-werks), he'll probably know... :wink: Quote Share this post Link to post Share on other sites
jezzaG60 0 Posted March 2, 2005 Wideband and narrow band sensors are not interchangable in any way. Nothing to stop you having 2 narrow band sensors.... 1 on the ecu and 1 for the air-fuel guage. Only way to really do it tho is to buy a wideband unit.... but they aint cheap! Quote Share this post Link to post Share on other sites
W3RKD 0 Posted March 3, 2005 Wideband and narrow band sensors are not interchangable in any way. Nothing to stop you having 2 narrow band sensors.... 1 on the ecu and 1 for the air-fuel guage. Only way to really do it tho is to buy a wideband unit.... but they aint cheap! agreed. this is a nice piece of kit if you want somthing that actually works.. :lol: http://www.webcon.co.uk/alpha/lambda_display.htm Quote Share this post Link to post Share on other sites
goodridge 0 Posted March 3, 2005 I didn't think you needed a seperate probe to run an air/fuel ratio gauge? :scratch: Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted March 4, 2005 I didn't think you needed a seperate probe to run an air/fuel ratio gauge? :scratch: no you dont i currently have mine tapped into the factory lambda probe, just thinking of ways to improve my current set up,, Quote Share this post Link to post Share on other sites
stevemac 0 Posted March 4, 2005 this is a nice piece of kit if you want somthing that actually works.. :lol: http://www.webcon.co.uk/alpha/lambda_display.htm Is that one quite accurate then Daz ? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted March 4, 2005 this is a nice piece of kit if you want somthing that actually works.. :lol: http://www.webcon.co.uk/alpha/lambda_display.htm Is that one quite accurate then Daz ? yes it is a genuine wideband for under £200 not bad imho. Quote Share this post Link to post Share on other sites
goodridge 0 Posted March 4, 2005 How do you go about adjusting the air/fuel ratio on the road then mate? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted March 4, 2005 How do you go about adjusting the air/fuel ratio on the road then mate? u would need a bloody long arm... :lol: :lol: this is just a far more accurate gauge not a tool for adjustment Quote Share this post Link to post Share on other sites
goodridge 0 Posted March 4, 2005 I thought so! :lol: So presumably you can only set it at idle, then the map on the chip should sort the rest? And what happens if its out? Quote Share this post Link to post Share on other sites
