Rawhide
PLEASE HELP! Firing order question..
Argggggggggh.. I brought the car ('92 VR6) home to my folks place to sort out the HT leads. I had a slight misfire at just around the 1750 rpm mark. It really was slight and not allways noticable.
My mate got me a set of Champion HT leads that fit fine. I have made sure they are all tight on the plugs but when I start the engine it doesn't want to idle and sounds rough :cry:
I thought at first it was just a bad lead so I have swapped back each lead at a time with the original but it doesn't help. I can only think that I have somehow messed up the firing order!?
The distributer cap has number on and I haven't removed it at all. I have traced the numbers back to the plugs and my firing order as looking at the engine from the front is;
153
246
Is this right? The only other thing that I could have balls up is I removed a couple of electrical plugs/sensors and sprayed the contact with carb cleaner :oops: They were the two black ones just to the right of the engine block. One is nearest to the engine fan motor and the other sits on top of a silver tube at the top right of the engine. They are both snug back on so I don't know what I could have done wrong!?
I really need to get out of here today as I have lots to do so I don't need car trouble :cry:
Can anyone help!?
Well I dont know the order from past experience, but I am hunting on the net for you right now...
Got it... its 1 5 3 6 2 4.. thats where you went wrong :)
And I have confirmed that by checked a number of different sites.. they all say the same firing order :)
THANKS Jim, I tried that but it made it worse!!
OK I now know the order should be 1, 5, 3, 6, 2, 4 on the diz cap..
what I don't know is which cylinder is which..
I am guessing the pattern is like this.
*00
000 = 1
0*0
000 = 5
00*
000 = 3
000
*00 = 2
000
0*0 = 4
000
00* = 6
therefore
153
246
I don't know much about v6's but that seems wrong to me.. It doesn't seem balanced..
Its
135
246
You might be able to just read the yellow tags on my HT Leads.
I have a coilpack, so can't show you the dizzy end - since I haven't got one!
I'm sure the plastic tracks that the HT leads lie in are numbered too, though....
Update - I have now assumed that the cylinders are names (as you look at the car)
123
456
tried this with firing order 1,5,3,6,2,4 but it didn't work.. I'm gonna try
654
321
Andi and Jim - buy yourselves a nice cold beer and put it on my tab!! The car is purring once again :D :D :D
Andi - you were absolutely right, the tracks are marked and so is the dizzy cap :oops: :oops: Even a monkey trained to recognise symbols could have done a better job than me :lol:
If you guys are coming to the Ace cafe I shall buy yous a non virtual drink!
Hehe... i'll make myself a 'Rawhide owes me a beer' voucher and hang onto it :)
Ace cafe is a bit far for me.. hehe.
Hehe, can I have two beers, since I took a photo? ;)
And just to prove I exist, you can see my shadow...
......and what an ugly shadow ;)
:lol:
