Rob_B
voltage regulator
is the amperage of the alternator on the g60 a standard size? eg 90amps? or can you get other ratings for said car?
this then leads me to the second part of the enquiry......
is the voltage regulator on the g60 a standard rating? or are there a variety of regulators? this would obviously only apply if you can get different size alternators!
cheers once again guys and gals
G60 standard alternator is 65a, you can get a 90a but its stupidly expensive!
Not sure about the regulators - I thought they were all the same from speaking to a local autoelectrician...
