khurrado
HELP- COOLANT WARNING LIGHT
far left of my dash, flashing, assuming its a coolant problem. What type of coolant do i put in? Can i do this myself?
mine blinks at me when I go over a hill, except it doesnt blink it stays on. it will stay on for about 15 seconds then start blinking when temp goes up as well. there is plenty of G12 in the tank, and the temp does get pretty high, could this be a bad black sender unit or is something else wrong.
Mine used to blink when i first started the engine on on the morning and then if i were to stop the engine and restart it it would settle down and not blink.
I have had two new tanks in the last year both with faulty senders in the expansion tank. I beleive it blinks because it cannot detect a flow of G12 returning through the system which arrives into the tank from the small pipe on the upper side of the tank. Last time as a matter of course i also changed the Blue and the Black sensors from the front of the head just in case.
