Andi
Dial-face template
So, here it is...
Andi - how come your ABS warning light is next to the headlamp switch?
All other C's I've seen have it at the top of the switch pod to the left of the steering wheel.
Cos I have aircon, which takes up two slots at the bottom of the left button array with "Norm" and "Max" buttons - so the ABS was moved to the useless "Unleaded fuel" panel, it would seem.
Or whatever is usually there in a late-spec C.
Cos I have aircon,
Now I'm even more confused - I thought those buttons were in the Cig Lighter trim surround towards the top?
Ah well....
Ollllld image here from when I first got the car..
You can just see the Norm/Max buttons...
Big thanks to ANDI
Been trying to create my own dials with his template, been trying to put my car in background.
with some fine tutoring of paint shop pro my dials are coming on nicely
cheers m8
Has anyone got the templates for the 1.8 16V ? (analoge)
Got well underway on psp, and now want to sort it onto the exact dials if anyone can help
Heres a pic of what i been playing with so far for my dials, not everyones tastes i know.
still some more work to do as mine is 1.8 16v
ehmmm... so you'll need to change the rev counter to 8000 rpm... and... try to fade out the pictures... the sharp edge gives it a cheap look i think..
i'm just starting to use psp, thought i would give it ago on the dials of andi's and if they didn't seem to difficult to do. i was going to use the template for the 1.8 which i got from your link cheers, still playing.
but i know what your saying, more practice and they should be sweet hopefully
Hans, how easy are the neon lights to fit and what type of bulb is used. I'll be trying this out in a coupla weeks.
ive finally got off my arse and put my white dials...looks nice aswell..cheers guys
Nice one, Dazzy.
But read the rules - you gotta post a pic of it now! ;) Hehe.
but ive gone and fcucked my speedo uo,doesnt start working till i hit 20ish mph,with it being electronic is there any way of re-setting the speedo?
Is it still accurate, or is it 10mph out?
If still accurate, you may have pressed it too hard and it's just the friction of the needle and the paper stopping it.
If 10mph out, get to the dials - pop off the needle, and replace it pointing at the bottom corner of the dial - if you sort of imagine it, its about 0mph. Make sure its firm, then bend it over the needle-stop.
HTH.
done away with my home made white paper dials and got myself some..
nice aluminium premier dials off ebay :D
Steering wheel looks nice 8)
What/which/who/when/where model is that then? :D
thats a raid hi tech steering wheel,purchased off brokescourt of the forum for £80 i think,spoted one in demon tweeks the other day selling for £150
