potatonet 0 Posted March 19, 2005 ok been having problems getting my car past 500 RPMS a lot lately, dont know what it is, though it was a vacuum leak. well before I work on it tomorrow I thought tonight I would check to see if I could hear anything first, I start the car and it sits at 500 again, I unplug the blue temp sender and it makes no difference, I just replaced the sensor 3 days ago and it made a slight difference then, it allowed my revs to go up for once, wondering if there is faulty wiring somewhere cause I dont know where it is. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 19, 2005 You can dump the temp readings out using VAGCOM. If the sensor is broken, it'll be obvious from those. Quote Share this post Link to post Share on other sites
Guest Posted March 19, 2005 There are a few was to test this sensor, if you look at the electrical tests in the Bentley manual it shows how to test this. You can measure the resistance at the switch and then check it at the ECU and see if you get the same reading. If you have a VR6 you can hook it up to a VAG-COM and then compare the data block with the ECU temp signal to the temp gauge in the dash, they should be very close. Cheers, Dennis Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 19, 2005 He's got a G60, you can measure the resistance accross the pins from cold and you can also swap the blue and black plugs over to test... Quote Share this post Link to post Share on other sites
potatonet 0 Posted March 19, 2005 ok its not the blue temp sender its something else, sensor reads fine. the car idled correctly for about 10 seconds after I altered the vacuum pumps hose config, I revved it and it dropped back down to crappyness, it just sits low, I have fuel flowing out because the spark plugs are black and the excess is coming out exhaust, computer is being retarded and getting snagged on something that is making ignition idle at 500, I am about to take it to a shop, 3 hours of testing till I do, If anyone just randomly knows what it is CALL ME. I need this thing to work today. 1-707-477-4203 Quote Share this post Link to post Share on other sites
beavis 0 Posted March 20, 2005 When you unplug the blue temp sender it should go into service mode unless you have a second sensor failed somwhere else. Digifant can compensate for one sender failing but as soon as you unplug the blue temp sender the ECU sees its as having two senders down, hence why it will not go into service mode. Check the resitance across the two sender pins on the blue temp sender when the engine is warm, it should read in the region of 250-300ohms. If your sure that the vac hoses are all connected securely and are undamaged check the voltage that the alternator is kicking out. Anything below 12.8v and digi goes into overfuel. You should see a good 13.8v with all electrical ancilaries switched on whist doing this test. Quote Share this post Link to post Share on other sites
potatonet 0 Posted March 20, 2005 ok sounds good will try this, there must be another sensor failed elsewhere I cant think of any besides black water sensor, what sensors could fail and where are they? I have replaced oil pressure and temp along with blue water, thermo, and aux fan. Quote Share this post Link to post Share on other sites
potatonet 0 Posted March 21, 2005 I am thinking grounding wire perhaps Quote Share this post Link to post Share on other sites
Henny 0 Posted March 21, 2005 could well be dodgy grounds... Quote Share this post Link to post Share on other sites
