JT 0 Posted March 19, 2005 ok guys i reckon this is a question for kevhaywire, i am thinking of buying an omp front upper strut brace for my mk2 16v, can anyone answer my questions can i fit it myself will the camber tracking need doing what difference can i exspect is it worth it and finally what is involved in fitting it sorry for all the questions but never looked into these before!!! Quote Share this post Link to post Share on other sites
Henny 0 Posted March 21, 2005 *beep* Kev's on holiday for a week... leave a message before the beep and he'll get back to you when he returns... ;) :lol: Alternatively: Camber won't be affected unless it's an ajustable brace and you tighten it up a stupid amount and pull the strut tops closer together! ;) :lol: Differences? It'll tighten up the front suspension meaning that it'll feel slightly more positive going into corners and will eliminate any "scuttle shake" that you may have Fitting? Depends on the design of the brace... some of 'em are as simple as undo the 2 strut top mounting bolts per side, put the brace in place, replace bolts... 8) Others need some more holes drilling and M8 nuts and bolts putting through to hold it tight... I've not fitted one to a MKII, but the 2 I've fitted to MKIs have both been of this design and can be fitted in about 30 mins... 8) Good luck! 8) Quote Share this post Link to post Share on other sites
JT 0 Posted March 21, 2005 cheers buddy just all the answers i needed... Quote Share this post Link to post Share on other sites
