Jay_vr6 0 Posted March 28, 2005 I have a bmc coming this week and am thinking of removing the carbon canister to allow the air feed down into the bumper. I have done a search of the forums and read hundreds of posts on the canister removal which all seems pretty straight forward but i really need to know what size breather filter i should use on the pipes (bore size so it attaches to the pipe) as i'm considering taking the canister out permanently. Now do i need to put a filter on both pipes ? Will i need to replace the canister for my Mot ? Any other suggestions or tips ? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted March 28, 2005 No need to remove the carbon canister! Takes about 2 minutes to relocate it :D Simply undo the screws, carefully pull the clear hoses out of their clips in the wing, and slot the carbon canister under the MAF. It's a perfect fit. Cable tie it in place (you'll need a long tie). Job done- and no need to worry about MOT etc and also no need for a breather filter. Quote Share this post Link to post Share on other sites
Jay_vr6 0 Posted March 28, 2005 a ha i was under the impression that the pipes weren't long enough ? if they are then this is perfect. thanks Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted March 28, 2005 No worries! They're easily long enough :) Quote Share this post Link to post Share on other sites
