Codo93g60 0 Posted April 1, 2005 Ok, i have 2 questions. first, what is the easiest way to get more power, and when I bought the corrado it don't run! it was running when he had it. he did some work on it, still ran, but stopped running. Anyone know whats wrong? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted April 1, 2005 some more info would be good, like whst did the other guy "work on" does it crank/turnover? welcome to the forum by the way Quote Share this post Link to post Share on other sites
stevemac 0 Posted April 1, 2005 Codo93g60, Welcome to the forum m8 Start looking for your problems by re-checking what your friend has done to it. Then check the DIY section on http://www.snstuning.com Quote Share this post Link to post Share on other sites
potatonet 0 Posted April 1, 2005 93 g60, good car, when they went digital on G60's. post something like, it cranks but it doesnt fire, does it even crank? more infomation would be nice. Quote Share this post Link to post Share on other sites
Codo93g60 0 Posted April 2, 2005 yes it cranks but it is a 92, i have thoughts about the fuel pump?? Quote Share this post Link to post Share on other sites
Reggit 0 Posted April 2, 2005 Does it spark? Is there fuel reaching the cylinders? Quote Share this post Link to post Share on other sites
potatonet 0 Posted April 3, 2005 take a spark plug out and place it connected on the engine block, if you can have someone start the car you can see if it sparks. also see if your injectors are putting out fuel by removing a different spark plug to see if it is wet after trying to start. my car did this, had spark and fuel, fuel was at full spray, ECU fried. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 3, 2005 yes it cranks but it is a 92, i have thoughts about the fuel pump?? Do you hear the pump prime when you turn the ignition on, Also check the wiring to the Hall Sender (distributer) Quote Share this post Link to post Share on other sites
