VEEDUBBED
G60.16V
Who can burn me a
digifant chip for the
ECU (G60) on my G60
16valver?,SNS,Pitstop,Jabba?.
I already have a BBM stage 4 chip
that i ran briefly when i first bought
this corrado and i'm not impressed...
Air/fuel all over the place when on boost,
I even tried this chip on the car when
i fitted a KKK24 turbo of an Audi 5000,
no change.I don't trust the sites/tables have
been done well or if digi lag has been eliminated..
Cheers.
Buy an SNS that's close to your spec, then get it setup properly by someone with a rolling road.... Can't help you with who as you're in Italy and I'm not... ;)
With the engine you're running, you're going to have to get a custom map as nothing else will match your setup properly, so you'll have fuelling holes and peaks all over the rev range if you use an "off the shelf" map... ;)
Good luck! 8)
Thanks,
If all goes well with the engine
and i like the engine i'll ditch the
G60 digifant and go stand alone or
Weber/IAW.
