surfer.vr6
coolant leak vr6
i have a coolant leak on my vr6 from around it seems at the top r/h of the radiator as you are facing the car, i changed the seal under the plastic housing that is held by two bolts but the leak is still there, it looks like the leak is coming from this housing unless there is a hairline crack in it.
is this a common problem on the vr6?
Looks like I have this leak - Can I buy the part sepaeratly or do I need a new rad?
Anyone with ETKA got a part number for the angled housing?
elbow and new rubber are £10.44 from vw, I just brough them a few weeks ago, use a decent bit if silicone grease when fitting though :)
