jay-bee
fitting boost gauge!
right! ive just got a boost gauge for my g60 but havent got a clue how to fit the bastard! can somebody post up a quick pic just showing were the t piece cuts into whatever pipe it needs to so i can fit the bugger!!!
regards
jay-bee
You can use the small hose coming out of the intake manifold. As you look at the manifold its coming out towards you on the far left.
the only one that comes out to the far left is pointing towards the bulkhead on the back of the inlet manifold?
if youre using a plastic hose you should tap it into the vac line going to the instrument cluster. if you run it to the inlet manifold the heat will make it crack.
if you're using rubber hose the inlet manifold should be fine. if you take out your carbon cannister there is a spare connection for it on the inlet.
