Baz2004
Temp Sender
Can someone please clarify an ETKA number for me:
049 919 501
It s a temperature SENDER for coolant temp gauge which controls the ISV. I have an early 16V and I need this part. Ive ordered it through 2 dealerships and got SENSORS both times!
In the remarks colum in ETKA there is a second part number 027 919 501 this is the number that is on the broken park I need.
I need urgent clarification on this if anyone can help me.
Tell me abot it Olly !
Im just wondering if the part is updated with a sensor does the clip and wire (green+red) stay loose or will I cut them off?
Dunno about that. My ETKA recognises the number and calls it "temperature sender" and under remarks it says "+ 16.0 MwSt"
There doesn't appear to be any kind of reverse-lookup function in ETKA so I can't see a picture or tell what car it's supposed to fit.
hth,
Olly
btw the descriptions and remarks are the same for both part numbers you mention above, the 049 one is a supersession of the 027 one.
Eventually found it under 4-cyl KR/9A electrical systems. It's described there, as you say, as gauge/ISV sender and it also mentions that it's a 1-pin device that's black.
Hope this is of some assistance.
Olly
yeah I have 049 in my hand here its definitely a sensor and not a sender. Ill try it on the car at the weekend hopefully it has the same function. I’m still stumped as to what to do with the loose wire and plug :?
Cheers for taking the time to help out anyhow.
