markievw
abs brakes
hi
Have a m plate vr6. Should the abs light ( one on left of instrument panel)come on when you start the car for a few seconds and then go out. Mine doesnt seem to come on at all. Is there anything wrong with it?
Also is there any advantage to changing the gear box oil on a regular basis?
cheers
mark
Put you foot on the brake pedal and then start the car. The light should come on with the ignition and then go off after a few secs.
You should also feel a small pulse through the brake pedal...
Yes the light should come on then go off. MOT failure if it doesn't...
All C VR6s left the factory with ABS.
Pulse through the pedals will only be noticeable once you go above 10kph from switch-on.
