Shaggy
red injectors and 3.5 bar Regulator?
Will adding these make much of difference to my already modded G60? (Pitstop Full Blend charger,Stage 5 SNS chip, Miltek System, K&N Panel Filter)
Regards
Mike
sick. thanks. this is what they said, what milage can I expect to get with it and the 30# injectors.
Stage 5-5, Same as stage 5-4, except for 30# or 42# injectors, custom maps for your motor.
right now I have custom map and get about 16 mpg.
If your getting 16MPG (!!!) then you've got a serious problem or you need to get the car set up correctly.... any standard G60 should be able to return over 30 and a tuned one around 25MPG...
Then again fuel is alot more expensive over here and very few of us could afford to run a 16MPG car....
