TomB 0 Posted April 26, 2005 My odometer and trip have stopped clocking up the miles, although everything else in the unit still works. Am I right in thinking that it will be part of the speedo cable coming out of the back of the unit? If so, does anyone know if these cables are interchangable with MK2 Golfs, Passats etc? The car is a 1990 1.8 16v (and any photos or tips on the repair would be much appreciated). Cheers, Tom Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 26, 2005 The speedo still works then? Quote Share this post Link to post Share on other sites
Musicman 0 Posted April 26, 2005 Is it analogue or digital? I've just been fixing the odometer on my Rocco - common problem with VDO dials. Handy links http://www.garageprosoftware.com/sciroc ... ometer.htm http://www.vintagewatercooleds.com/tech ... ometer.htm http://www.pelicanparts.com/techarticle ... repair.htm Quote Share this post Link to post Share on other sites
TomB 0 Posted April 27, 2005 It's the analogue one, and the speedo, tachometer and verything else still work fine. Musicman/ thanks for the links, I'll check them out as soon as I get a moment. Cheers, Tom Quote Share this post Link to post Share on other sites
Henny 0 Posted April 27, 2005 This is often caused by the little cog on the end of the milage counter becoming jammed or coming loose... The same thing used to happen to Beetles, Golfs and other VWs with mechanical milage counters. The other thing that can happen is that the reset for the trip jams up the mechanism and stops both counters from moving.... :| Remove the clocks, open 'em up and you'll see on the end of the shaft which has the numbers on it the small cog which is driven by a worm gear... make sure that these are clean and will turn when the speedo cable turns... 8) It's not rocket science as to how these work, but it is a little fiddly and involves lots of small parts, so be carefull not to drop any! ;) *edit* d'oh... just visited Musicman's links to find they say what I just said in this post... :roll: :lol: Quote Share this post Link to post Share on other sites
TomB 0 Posted April 28, 2005 Much appreciated gents, a task for the weekend I think... Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted May 6, 2005 if you replace the digital dials on a late VR will it lose mileage on the display? I.e is it stored in the dash or in the ecu? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 6, 2005 Yep, it's stored on the gauge cluster - Guy Hartley will be able to correct it for you tho... Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted May 6, 2005 ok, the prob I have is the trip reset button refuses to work.. would some1 be able to fix that? Quote Share this post Link to post Share on other sites
chargedupstorm 0 Posted September 29, 2005 Yep that can be repaired too ;-) as well as the mileage! Quote Share this post Link to post Share on other sites
