Baz2004 0 Posted April 28, 2005 Anyone know the model nos of these pipes A and B? Im having a messy leak out of them onto the flange :) no joking intended, I presume its the leaky pipes that's causing this problem? Would pressure build up water/oil be another cause?? Its a 16V 1.8 engine Quote Share this post Link to post Share on other sites
Henny 0 Posted April 28, 2005 that's just a breather pipe... The odds are that someone's over filled the oil slightly at some stage and it's escaped there... Take off the pipe and clean it up and see if it gets messy quickly again... if it doesn't then you've sorted it... ;) Oh, and check that it's not blocked inside as this would cause it to leak slightly too... It's normal to see 'em like this on valvers... 8) Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted April 28, 2005 Fit an oil catch can? Quote Share this post Link to post Share on other sites
