Jay_vr6
Worrying Vag-Com fault codes ABS related Help!
Just got Vag com and run the complete test and it's thrown up these 2 errors
00287 ABS wheel speed sensor Rear right (G44) 35-00 --
00290 ABS wheel speed sensor rear left (g46) 16-00 - signal outside specifications
The car is a 94 VR6 and was idling at the time
What is my course of action ?
Assuming that your ABS light still has the bulb in it and goes off after you start the ignition then I don't think you have a problem- because whatever faults the car may have had on the back ABS sensors must have been fixed- just the codes not cleared out.
I believe if you have your car rolling roaded then it will also log faults on the back wheel sensors too..
Cheers
Mike
ahh yes the ABS light does indeed flash a few times when i start up, is there a way on vag-com to remove all the old codes ?
Yes there is an option to clear out all the codes. If you lookon autoscan and there is an option to clear all 'DTC's- I'm pretty sure thats the right one but check the vag-com manual just to be sure though..
Cheers
ABS light on start up for 1 to 2 seconds is normal.
Has the Corrado been on a rolling road at any time? If so, because the rear wheels are stationary, these sorts of faults get generated.
handbrake turns also make these error codes crop up... :twisted: :lol:
it'll be the fault codes from where a tosser tried to kill me and the rear passenger wheel ended up disintegrated on a curb, cheers gentlemen :)
