tattyrado
Waterpump bearings noisy as hell
The bearings on my waterpump pully on my 91 G60 are shagged, need to fix it quick as a bloke is viewing the car on Friday. What do I need to do? I presume it involves repalcing the whole pump, if so can anyone walk me through it? ( I did search the forum archives but cant find a "how to" anywhere).
Ta
Chris
All I know is, you need to whip the charger off to get at it.. so it might be a bit more of an involved job than you were hoping! :(
.......and the power steering (if you have it) ......and the alternator.....
does the G60 have a different setup to the 16v?
Well, the pump is in the same place but it has a bracket and the the charger stuck ontop of it making it quite a big job... PAS stuff is ok where it is tho...
Xchange pump from VW is about £25, get a new stat as well (fiver)
