bullockm 0 Posted May 10, 2005 Want to lower my G60 C which is on standard BBS which I want to keep. Just want to improve looks and maybe a little bit better handling. Any thoughts???? Cheers Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted May 10, 2005 How deep is your wallet? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 10, 2005 I take it your suspension is original so you want to get shocks / springs along with new front top mounts and rear bumpstops as a minimum.... Either Koni Coilovers or a Koni shocks and H&R springs seem to give the best results from what i've seen altho there are cheaper options available Quote Share this post Link to post Share on other sites
bullockm 0 Posted May 10, 2005 I dont want to spend too much, im happy with the handling of the standard set up as I dont race about, getting too old for all that. I just want to improve the look as it sits a bit high. Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 10, 2005 35-40mm drop is comfortable and shouldnt cause you any problems with regards to wheels rubbing. i went for the "cheap option" and just changed the springs etc....but have been more than happy with the handling..ride....and looks ever since.....its a mod that is a MUST really! Quote Share this post Link to post Share on other sites
bullockm 0 Posted May 10, 2005 what springs did you go for, I heard that AVO were quite good and reasonable? Quote Share this post Link to post Share on other sites
Bally 0 Posted May 10, 2005 Wouldnt use AVO.. I'd get Eibach or H&R.. Quote Share this post Link to post Share on other sites
bullockm 0 Posted May 10, 2005 So AVO no good then, Eibach's are 3x the price, are they 3 times better? Quote Share this post Link to post Share on other sites
Bally 0 Posted May 10, 2005 yeap better ride too.. AVO arent bad, its upto you.. Have you rung Venom motorsport?? havent got there number to hand.. Quote Share this post Link to post Share on other sites
bullockm 0 Posted May 11, 2005 I will try venom MS. Cheers Quote Share this post Link to post Share on other sites
