woody
Vibrating rear panels
Has anybody got this annoying problem. Above 60 mph the panels either side of the rear seat vibrate at the top. Should the panels be connected to the bottom point of the window with the same clips as the front windows?
Are there any hidden screws in the these panels apart from the ones which can be easily seen.
if you pull the seat backs forward there is a screw at the top neat the seat belt, the panel its selt is mostly cliped in with one or two screws round the outside, and door piler
