brian g60 corrado 0 Posted July 8, 2003 has anyone had this fault or is it normal.when i park up and switch off engine lock car and a few minutes later rad fan cuts in like normal but also it sounds like the fuel pump also cuts in and operates for about 5-10minutes.if anyone can sheed some light on this would be great .thanks everyone this is a very good forum it has helped me loads Quote Share this post Link to post Share on other sites
julesz 0 Posted July 8, 2003 I believe its normal. Mine does it too. I think maybe something to do with keping fuel cool rather than left getting warm in the pipes??? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted July 8, 2003 Its normal, i think its to cooler the fueling too as a hot fuel system leads to fuel vapourising and the car not starting, Common fault on R19 and R5 turbos i believe. Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted July 8, 2003 thanks guys ithough it was normal as it seems to cut out eventually,just though i would check with others Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 8, 2003 Hmm, I'm glad someone asked about this again, I had been told it was normal but wasn't sure... when I get a minute I'll have a look at the wiring diags and see if its connected to the rad fan run on (it certanly appears to be) Mine is sometimes quite noisey - altho I can't hear the pump from inside the car when the engine is running - you can when you switch off (or on without starting) Quote Share this post Link to post Share on other sites
G60Jet 1 Posted July 9, 2003 altho I can't hear the pump from inside the car when the engine is running - you can when you switch off (or on without starting) Try changing your fuel filter, that will make the pump also silent from in the car. :wink: Quote Share this post Link to post Share on other sites
Rams 0 Posted July 9, 2003 Is it definitely ok for the pump to be working whilst the car is turned off? I would have thought this dangerous and the pressure is not being realised. Or is it. My mates yellow G60 does it and I though it would have been a relay problem, as it would stop then start after a few minutes as so on. If its definitely safe and what they are supposed to do then I will inform my mate that its ok. Quote Share this post Link to post Share on other sites
