Blue_Joe 0 Posted May 25, 2005 Been offered a TSR 4 Branch Unused for my G60. Have any of you guys had one?? Any feedback before I agree to buy?? Thanks Sam Quote Share this post Link to post Share on other sites
Henny 0 Posted May 25, 2005 they're a pig to fit... They're pretty well made, but you must make sure that your engine mounts are spot on else you may end up cracking the 4 branch... ;) They should give you a slight torque increase but will help free up any other mods power... 8) Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted May 25, 2005 Got a solid front engine mount from JMR. Going to check the others in next few days! I won't be fitting until I change my head I think as don't want to shear off a bolt in the head which is bound to happen. Might give it a go though as I have all inlet manifold off at the moment anyway. Dunno - risking shearing those bolts worry me!!! Quote Share this post Link to post Share on other sites
W3RKD 0 Posted May 25, 2005 drop off the front engine mount lower the front of the engine then there a piece os pi55 to fit should take no longer than 2hrs max.. Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted May 25, 2005 Thanks Darren If I get it will fit it this weekend just before having the new Longlife Exhaust fitted Quote Share this post Link to post Share on other sites
Henny 0 Posted May 26, 2005 g-man said: drop off the front engine mount lower the front of the engine then there a piece os pi55 to fit should take no longer than 2hrs max.. Oooh, that sounds like the voice of experience there... 8) I'll remember that... :) Quote Share this post Link to post Share on other sites
g60bv 0 Posted May 26, 2005 yes they are good, but when they get the lambda point welded on, make sure they don't weld it onthe side. they cocked mine up, theres no room in the tunnel, in must be on top and facing the engine. in the end i chopped the end off and sorted out the poxy 2" out let as well. see pic Quote Share this post Link to post Share on other sites
