Baz2004
G60 brakes
Does anyone know if its possible to use 280mm disks on 16V calipers & carriers?
Will 16V pads work with the G60 calipers?
Anyone know how much longer the lines are on the G60s?
The discs won't fit.
You can do it with G60 carriers and 16V calipers but the pads will be too thick. You can take some off the pads though.
I don't think the lines are any longer.
Gavin
Barry, the G60 Carriers are bigger, the G60 pads are thicker, so if you use 16V calipers you need to use 16V pads
16v Caliper will fit onto G60 Carriers with the use of 16V pads
When your going to that hassle you may aswell fit the G60 calipers, and i have that brake line sitting at home for you too.
