Baz2004 0 Posted June 7, 2005 Looking for advice and places to get a decent front engine mount for my 16V. Quote Share this post Link to post Share on other sites
ben16v 0 Posted June 7, 2005 JMR or vibratechnics (spelling) Quote Share this post Link to post Share on other sites
chrishill 0 Posted June 7, 2005 I can recomend the vibratechnics engine mount, fitted one to my VR and it made a whole world of difference! looking at around £120 IIRC unless you can get one second hand as I did. Some people would say the OE one will do you fine, depends what you want from it and how knackered the current one is. Uprated ones reportedly transmit more vibration from the engine, although I have to say mines still perfectly refined. Quote Share this post Link to post Share on other sites
ben16v 0 Posted June 7, 2005 or i`ve heard that mk2 diesel mount is solid??!?!?!? Quote Share this post Link to post Share on other sites
chrishill 0 Posted June 7, 2005 I 'think' the VR ones are oil filled and the mk2 diesel ones are all rubber...could be wrong? Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted June 8, 2005 The JMR I have I have improves power transmission and costs only £70 from 16VG60. Quote Share this post Link to post Share on other sites
Baz2004 0 Posted June 8, 2005 What’s involved in fitting them? i.e is it possible to do without stripping the engine/exhaust manifold? Quote Share this post Link to post Share on other sites
g60_Pete 0 Posted June 8, 2005 its a bit fiddly but i fitted mine to my G60 by just diconnecting a few pipes and wriggling it around :D mines got a JMR solid mounth now and it does transmit alot more vibration when you really punch it, but for everday driving you dont notice. good price though! Quote Share this post Link to post Share on other sites
AKA-Andrew 0 Posted June 8, 2005 Get one of the above, I have Vibratechnics front, back and gear box and I can highly recommend them, yes you do get more vibration from them but they are worth it, you really notice the difference. Quote Share this post Link to post Share on other sites
Baz2004 0 Posted June 8, 2005 Does anyone have a pic of an empty engine bay with all the mounts in? I presume a VR/G60 set will fit a 16V? Quote Share this post Link to post Share on other sites
h100vw 0 Posted June 8, 2005 VR front mounts are different to 4cylinder ones. The others are the same AFAIK. Gavin Quote Share this post Link to post Share on other sites
Rpmayne 0 Posted June 8, 2005 When I took my VR front mount off it wasn't oil filled. There's two rubber parts, a larger part that sits above the cross member, and a smaller part below. The top part just had loads of holes through it to make it more flexible. I changed the bottom part for a turn2 polyurethane replacment (£20) and it stopped the engine rocking about but hasn't introduced any extra vibration. Overall happy with that although this could probably still fail and give the bonnet some extra power bulges. I'm personally abit sceptical of these completely solid engine mounts. It must introduce more vibration, and because the engine tends to twist (especially if the other mounts are left standard), if there's no give surely the bolts are going to be under alot more strain and could shear?? Can't see how the cross member bushes deal with this alone. Expecting to be shot down for this view..... :) Quote Share this post Link to post Share on other sites
Baz2004 0 Posted June 8, 2005 there's no give surely the bolts are going to be under alot more strain and could shear?? Can't see how the cross member bushes deal with this alone. :) I’ve heard of people welding the front mount on their track cars for this reason. No matter what mount they use the bolts always give out, poly cross member bushes can last longer but may increase the problem with more vibration. Quote Share this post Link to post Share on other sites
Louie Lungbubble 0 Posted June 8, 2005 My front mount's gone as well... Was gonna get an oem one at the weekend but dunno now. Are the JMR solid mounts different from the golf diesel solid ones? How much do oem ones cost for comparison? Quote Share this post Link to post Share on other sites
h100vw 0 Posted June 8, 2005 Louie, they cost naff all. I have a soild one from the Passat that I broke. You can stiffen them up if you have the facility to weld it back together. I lent my MIG out. If you want it for a fiver let me know. Gavin Quote Share this post Link to post Share on other sites
Louie Lungbubble 0 Posted June 8, 2005 Jesus. Just been onto VW. £119.49 for a Corrado oil filled front mount, and £87.67 for the 1.8 D Mk 2 Golf solid one. I'm suddenly reminded why we call them Stealers! What is it that needs welding on that one of yours, Gav? Quote Share this post Link to post Share on other sites
h100vw 0 Posted June 8, 2005 Nothing if you want to fit it as it is. What I did to the one on my syncro is pull it apart. You have a rubber block filled with holes. I filled most of the holes up with a load of old bolts. I then welded the top back on. Not got any pictures but come over and I can show you what's what. Or like I say just fit it as it is. Gavin EDIT GSF do them for less than VW. The one like mine is 24.50 plus VAT. The Hydro one is more. Quote Share this post Link to post Share on other sites
Louie Lungbubble 0 Posted June 8, 2005 Ahhh, nice one mate. SOLD! When's convenient for you to let me get it? Quote Share this post Link to post Share on other sites
Garry 0 Posted June 8, 2005 You can make the solid front mounts pretty cheaply - I had a couple of them made for £35ea! I have a set of detailed drawings for sale (£10) that you can take to a CNC machine shop and get one made. Quote Share this post Link to post Share on other sites
16VG60 1 Posted June 9, 2005 I have been selling my JMR solid alloy front mounts for about a year now and they have been widely and well received by all, both on and off the forum. I have had one fitted to my 16VG60 for all this time, and a little longer besides, and have not seen any signs of deterioration whatsoever. Given the torque output of my engine, and the fact that it destroyed a Vibratech mount i would suggest that JMR mounts are up to the job and thoroughly tried and tested. I personally have not experienced any undue vibration from my own car as a result of this mount, and i know this is also the case with the vast majority of my customers. I continue to sell these mounts as fast i can replenesh stock, so this allone tells me that they are a valid and well thought of component when a replacement is required. The asking price of £70 (plus £5 P&P for mail order) i feel is both fair and offers exceptional value for money, especially when the other options are twice as much! Fitting of JMR front mounts is simplicity itself and indeed made all the more easy through being a far less bulky item than the OEM mount, a deffinate plus point when you consider how crowded the G60 engine bay is in this area. I wellcome all enquiries on this subject and am happy to offer assistance with fitting instructions. Quote Share this post Link to post Share on other sites
Louie Lungbubble 0 Posted June 10, 2005 If I'm ever buying a new-un John. you'll be getting a shout, but cheers to H100VW for supplying the one I just got. Oh, Gav. By the way..... My missus, (after sitting, and watching me and yourself jibber-jabbering) said she thought there'd been a mix up at the hospital! I think that's a compliment mate. (to you, obviously) :wink: :lol: :lol: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 10, 2005 I'm personally abit sceptical of these completely solid engine mounts. It must introduce more vibration, and because the engine tends to twist (especially if the other mounts are left standard), if there's no give surely the bolts are going to be under alot more strain and could shear?? Can't see how the cross member bushes deal with this alone. Expecting to be shot down for this view..... :) So am I mate but the 4 cross member bushes have a LOT of give in them, especially 10 year old squidgy ones, so you can get away with it, just. Vibration is certainly transmitted into the cabin using a lower turn2 poly mount in the case of a VR6, so a solid metal can only be worse, it's simple physics! I have VT all round and poly cross member bushes and it's perfect. Holds the engine still round corners and reduces drivetrain shunting to almost zero. Being shot down in flames seems par for the course on here these days but don't worry about it, say your piece and let the people that don't like it lump it, basically. Quote Share this post Link to post Share on other sites
