A5 VRX
Pinking!!!
Really fed up of the car pinking! I've got a 1991 1.8 16v and when the engines hot and under load it pinks like mad. I've had the timing done in the past which worked for a little while and i've also used Redex which i think did sod all! Any ideas folks? Also the car has been run for the past 2-3 years on optimax so can't be the fuel? Will new injectors cure this?
No I don't think so.
The pinking is probably worse due to the hot weather. I think you may need to back off the timing until the cold weather comes back. Or get yourself a VSAM or Kstar fitted.
Gavin
If your timing is set up right and C.o is ok (check fuel pressure and control pressure are ok aswell)16v should run well enough with out k star they don,t need it unless your cr is way high
If the head has not been skimmed to death and all is well with the fueling
there is no reason why you car should pink if set right
I set them up all the time and have no problems
Edd.
P,s lack of fuel can cause an engine to get hot and pink
pull the injectors out ,jump the fuel relay and lift sensor plate
put the injectors into 4 clear bottles they should all have the
same fan and deliver the same amount in all the bottles
hope this helps :wink:
