A5 VRX 0 Posted June 25, 2005 Alright all, i have a 1.8 16v and just wondered what the timing should be set? Any help much appreciated, cheers Quote Share this post Link to post Share on other sites
RW1 0 Posted June 25, 2005 Hi, 6 degrees BTDC +/- 1 at 1,000 rpm idle speed (950 - 1050 rpm range). Check your flywheel timing mark beforehand to determine whether it is the TDC or the igintion timing mark. Sometimes TDC mark is not marked with a "0" or there is no TDC mark and the timing mark is the only one on the flywheel. Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted June 25, 2005 cheers for that mate, see what i can do tomorro then! Thanks for the help Quote Share this post Link to post Share on other sites
flusted 0 Posted June 26, 2005 You must disconnect the red/black wire by the coil to set the timing.Mines set at 9deg for best performance but you may get pinking Quote Share this post Link to post Share on other sites
