g60_Pete
adjusting alternator belt
how to on a 91 g60?
replaced the whole alternator last week, but not the belt as it was in good condition, it now however squeals like bloody hell, so im guessing it needs tightening up, how do I do this?
cheers.
The belt self tensions using the spring damper. the only way for the belt to be loose is if a, you have a dodgy spring damper or b, you have re-run the belt's in the wrong route. Does the belt look/feel loose ?
the spring damper seems fine.
used a new one and its the same size so far as i can tell but i shall double check.
also its run in the right routes. the belts also clean and seems to be about the right tension.
tightened all me nuts up (hehehehe) and its quieter but still squealing a little a tickover.
shall check the pulley.
