HyDeZaLoT
Idle/Starting Issues
since i got my rado, it has had a strange problem... sometimes when i go to start it, it just won't start... i hold they key in the start position and after like 7 seconds, it starts... also have an issue with the idle, its usually going b/t 300rpm and 2000 rpm... just bouncing back and forth. any ideas as to what i can try to do to fix either issue would be a great help. TIA
What engine you got, any mods?
It's quite possible that it's your ISV (idle stabilisation valve). If you search here you'll find loads of information.
if it's a G60, check that the idle switch is being pressed by the throttle linkage... sounds very much like what mine was doing when I forgot to plug the wiring to the switches in after a rebuild... :oops: :lol:
