StormchargedVR6
What a BRAKE SETUP
I LIKE IT :?
looks good. Probably go for 300mm disks with 2pots on the back of mine once i've fitted the smaller master cylinder.
You wanna be careful not to stick dis-proportionately massive brakes on the rear otherwise you'll start locking them up under heavy braking.
There's a reason that the fronts are much bigger ;)
LEE , Where you get your front brake set up. Looks good
Bought them directly from Hi-Spec. Took nearly 5 months to get them. They quoted 3 weeks :?
at the moment i need a little more rear braking as the 4pots feel like they could stand the car on its nose. think i'll firm up the front dampers abit this weekend.
