Ad2408
Where are the oil temp and pressure senders?
Hi
I have a 1991 16v and want to fit the Audi gauges I got hold of.
I've got the twin pole sender but....
I was just wondering where the senders for both the oil pressure (on top of the filter housing? But which should I replace with the audi pressure sender, the brown or the white one?)
Also where are the oil temp senders?
Any pictures would be great!
Adam
Oil temp sender is on the back of the head, geen wire with black stripe.
On the filter housing, you need to T off the left hand sender to fit the original sender back in AND the Audi sender for the guage.
not if you have the 2 pole sender, it replaces the single existing one.
David.
Thanks
Which one should it replace? The brown or the white? I presume one is high pressure and one is low?
Adam
