Riley
black plastic fuel thing???
sorry guys i dont know what it is.
its the thing that all the pipes run to,mounted on the drivers side strut tower,pipes run from it to the c/cannister i think?
anyway,today i noticed that as soon as i touch the throttle,it clicks?
is it supposed to? i never noticed it before.
cheers,neil. :)
Its the carbon canister control valve, dont think mine clicks, but even so I doubt its much to worry about :roll:
anyone else?
id rather sort it if its not right,the car does seem to be heavyish on fuel if thats anything to do with it or not i dont know?
c/o and timing are spot on and so is the lambda probe.
neil.
Buy a new one from VAG if it makes you feel better, yes g60s are heavy on fuel :?
yeap they click, there is a diafragm in there just delete the carbon cannister and associated piping, do a search on here to see how to do it,, you dont need any of that lot
g60`s are heavy ish on fuel riley,, about 32 mpg on the motorway, and in town well,,, 20mpg is not uncommon or much worse,,, takes allot of power
to spin that charger round when its not getting used,,
what do you mean by " heavyish on fuel "..?....what mpg are you getting?
I get around 25mpg - at 80mph .. :shock:
It get's into single figures around town. :(
cheers m8,it clicks as soon as i touch the throttle,even just a little,still ok?
will i need to reset the c/o mixture if i remove the c/cannister?
about 15-20 around town,maybe thats ok then? :oops:
cheers guys.
neil.
15-20 around town is right on the money as far as i can tell, g-man reckons an sns chip will see it improve. so i think im going to order one up as soon as i can work out how to worka multimeter and set up the copot!!
I was cruising back from halifax after a VeeDub show and i was getting 42mpg that was cruising at 50mph. Motorways i get around 28-37 and round town its approx 25. I dont think that is bad at all considering how thirsty a G60 is.
Oh yeah that is running on a SNS chip. No pulley yet though!!!
8)
