BigTartanJudge
MK3 VR6 1st / 2nd / 5th gear ratios, same as Corrado VR6 ??
Ok, I need VR6 1st, 2nd and 5th (plus reverse as on same shaft), already have G60 3.64 final drive, this is all going into my O2A MK3 16V Passat box with Peloquin ATB diff. So I will defo be able to use the 1st, 2nd and 5th from a MK3 VR6 gearbox, they are the same ratios as Corrado CHN code ratios and they will fit ok ?
Sorry for all the questions but don't want to end up buying something I cannot use (already happened recently when I purchased an apparently VR6 ratio gearset which by some VW mystery turned out to be 1990 Corrado 16V gearset and was useless for ratios I need :roll:
Cheers
Reverse is a little shaft on its own. I think it matched with 1st or 1st and 2nd on the input shaft. I've got a box in pieces so I'll check it out for you tomorrow.
