dazzyvr6
my engine is goosed
just did a leak down test on the vr6,only tried it on no.1 cylinder,and the liquid i used pretty much came out of the sump plug hole in a steady flow...looks like ill need a new engine :roll: :cry:
Thinners is far thinner than water and would more easily run past the rings.
Put new rings in, no big deal, you don't even need to take the engine out the car!
Chris
the thinners i used is actually thicker than petrol,i got it from where i used to work,cant remember what its called but it wasnt cheap :)
Can't state for sure that bore is bad then. Do the others. Also, a hot engine will be plenty different to a cold one.
Gavin
