boab
What to replace when putting new Springs on??
As my car is old and im assuming if i change the springs to lower the car, that i may also benifit from renenwing other parts of suspension etc, what exactly would i be looking to change and replace??
I did almost the same thing, I've ordered a new lowered suspension and the meaning was that you have to use parts of the original suspension tot mount the lowered suspension. So I've made a list with ETKA of parts that I need to mount the new suspension.
I've got an complete new suspension under the car and it drives very well.
fancy posting the list? :D
Im sure most of the front bushes would need replacing if the car is very old. New wishbones with poly bushes is a good start, steering tie rods can be fairly worn also if they are the original ones on the car.
Something like this??? :lol:
x2 N 0221501
x4 N 10174002
x6 N 10328602
x4 N 90323704
x2 1H0412319B
x2 357412341
x2 811412365
x2 171412369
x2 8D0512097
x2 191512113
x2 191512117
x2 191512119
x2 1H0512149
x2 191512337
x2 191512339
x2 191512340
This is not everything, some parts like the rubber mounts front&rear aren't from VW, they're from Monroe. The bumpstops and protection caps are also aftermarket parts. This stuf is 3 times cheaper than original parts and they're from the same quality.
Ps : The list is for a 1990 Corrado G60.
Hope rear bushes are on there too, they are a real Corrado weakpoint and affect how the car handles to a large extent. :)
No joke to fit the VW ones, easier fit the poly’s ;)
Any chance of a description of what is what?
Here's some of the bits I replaced, price from GSF IIRC:
front wishbone rear bush (bonded rubber mounting) 191 407 181D £7.50 + VAT *2
front wishbone front bush (bonded rubber mounting) 357 407 182 8.09 + VAT *2
rubber mounting, inner (roll bar to subframe) 191 411 314 1.93 + VAT *2
ball joint 357 407 365 12.37 + VAT *2
rear axle bush (bonded rubber mounting) 191 501 541 16.00 + VAT *2
lower bearing ring (rear damper to body rubber mount) 191 512 333 3.85 + VAT *2
upper bearing ring (rear damper to body rubber mount) 191 512 335 2.93 + VAT *2
105.34 + VAT
123.77
need to add 2 drop links to that, plus their rubber wishbone mounting doughnuts *4 and probably suspension top mounts
parts for a 1990 16v, most should be same for G60.
David.
Look at the picture in a previous post, thats what you'll get if you'll order this parts. :wink:
a load of bags with whits labels on them?
It's everything but the suspension (dampers and spirals/coils), just bolts and nuts. :wink:
ever heard the term " its like trying to get blood from a stone " mate?... :lol:
Never heared that term here in Belgium, we use other terms. :wink:
ok, any chance of re-posting that list but with a reader friendly description beside each part number please Dennis? :)
