Dutch24V 0 Posted August 15, 2005 Ok, will adjust that tomorrow eve. then and just develop a light foot for the drive to work tomorrow! Cheers mate... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 15, 2005 No worries 8) Quote Share this post Link to post Share on other sites
NickVR6 0 Posted August 15, 2005 1. ahhhh ballacks, having read this i will need one of these or i won't sleep! 2. Bit confussed about re-maps as i thought you could'nt tweak the VR that way? 3. Kev, is your new TB a 2.8? i don't understand. Sorry, being dimm as usual! Quote Share this post Link to post Share on other sites
Dutch24V 0 Posted August 16, 2005 :) ...exactly how I felt when reading simular posts Nick, so I got one. For 125 smackers (inc. posting) you really can't go wrong. I also brought one as the Unichip that came with the VSR from Asim was mapped with the VSR and an AMD enlarged body. Asim sold his body before I got a chance to have it so thought I'd better get the engine back to the same spec. the unichip was mapped on before fitting. I haven't fitted the VSR & Unichip yet so am running the TB with a standard mapping and it still makes a very noticable difference. Totally wakes the engine up accross the range and from 3000 she flies. I have a new MAF also so the extra airflow is definately picked up and the fueling increased acordingly. Not sure if you would feel the same benifit on an old MAF though?? Dutch PS. Kev, I quickly lengthened the cable this morning and now she feels a bit unresponsive between 1-2000 rpm. Guess I over did it so will *play* this evening to get just right. Quote Share this post Link to post Share on other sites
NickVR6 0 Posted August 17, 2005 Cheers Dutch, an email to the man hath been sent ! Not much you can buy for the VR around the £100 mark so this is well worth a try mate cheers. Quote Share this post Link to post Share on other sites
Dutch24V 0 Posted August 17, 2005 BTW, he's on holiday until next Tuesday I think! Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 2, 2005 So do I need to get a new TB gasket if I am getting one of these? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 2, 2005 The VR gaskets are all the reusable type, but you can change it if you want. I've taken throttles on and off about 8 times recently and used the same gasket throughout with no probs! Quote Share this post Link to post Share on other sites
Claret Badger 0 Posted September 2, 2005 so where can I get one from? sorry can't use the previous page button Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 2, 2005 Gasket or throttle? Email mailto:[email protected] if you want a throttle and just say the Corrado forum put you onto him! Quote Share this post Link to post Share on other sites
monVR6 0 Posted September 5, 2005 I'm emailing about one too. Only mods I have are a K&N Panel filter an AmD remap - I assume I can just change the TB - with no further adjustment?? How does this affect MPG - (not that this is likely top stop me getting one as it sounds awesome!!!) Quote Share this post Link to post Share on other sites
Claret Badger 0 Posted September 5, 2005 Gasket or throttle? Email mailto:[email protected] if you want a throttle and just say the Corrado forum put you onto him! throttle. I reckon this should improve my mpg no end - :) but seriously - yeah I'm interested in hooking one of these up to my VR Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 5, 2005 Just drop him a mail, think's there's a small queue at the moment, as he only has one Corrado TB to work with, so he's counting on us guys having a quick turnaround. He asked me if I have a spare 2.9 TB, so if you know anyone that does he would appreciate it. Quote Share this post Link to post Share on other sites
monVR6 0 Posted September 5, 2005 I may be able to start the ball rolling - (or dominoes toppling) - as I have access to another car, so the VR can be without TB for a while. Just need to see if I can scrape the cash together! Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 7, 2005 Righty then, got mine fitted tonight, but my throttle has gone loose. We put the throttle cable on the tightest setting, which helped a bit, but it's still stalling/idling at about 400. How do I get it tighter? Quote Share this post Link to post Share on other sites
Joe M 0 Posted September 7, 2005 The tension in the cable shouldnt affect the idle unless its too tight then the idle will be high. Check all the pipes and stuff again then do an ECU reset if your still having problems. Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 7, 2005 OK, will try tommorrow. The pedal still feels loose though. Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 8, 2005 It's not just idle though, the engine revs seem to drop quickly too. Could it be a gasket problem? Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted September 8, 2005 Not a head gasket i wouldn't have thought, but it sound's like it's since you have changed the TB so check all you have touched for cracks etc Chris Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 8, 2005 Yeah, I meant the TB gasket. Quote Share this post Link to post Share on other sites
VR6 0 Posted September 8, 2005 Everything was tightened up or put back together the way it should have been; throttle cable included. It doesn't feel like it's disconnected from the pedal end of things, although it feels quite loose. Can only suggest that the butterfly on the new one is a lot less springy than the old one. Although that doesn't particularly explain the stalling. Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 8, 2005 There should be no problem with idle unless the gasket is knackered,or the large rubber gaitor is split. You could also try your old Tps. I'll have a butchers aroung tonight to see if anything else has come loose. Tom - fancy coming for a drive to see what you think? Quote Share this post Link to post Share on other sites
VR6 0 Posted September 8, 2005 Sorry mate, I'm busy tonight and tomorrow - could lend you a hand at the weekend sometime though. Might just be worth taking it off, to see if there is anything loose or any splits etc. Maybe try the old one again if there's still no joy. Was it exactly the same this morning? Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted September 8, 2005 That sounds like a good suggestion. You may be able to wind the return spring round once more so it's more positive. Have you made sure that the TPS is correctly aligned and connectet and there is no break in the wires etc cos if you pull the plug off the TPS the engine will go funny and may stall, try unclupping the TPS while running and see if it makes a difference, if not then there's your problem. Chris Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 8, 2005 No worries, just wanted to make sure that I wasn't going mad with this engine revs dropping quicker thing! Seems to be quicker at lower revs too. Quote Share this post Link to post Share on other sites
