craigowl 0 Posted August 9, 2005 Original Speedlines on my car are in excellent condition. However, yesterday, with soapy water placed on horizontally laid wheel I have confirmed very slow leaks where tyre meets rim. (Pressure had dropped to 16psi after a fortnight) I know this is a common problem. What is a typical cost per wheel for the refurb of these alloys? Multiplied by four it might be a lot, so I could perhaps get just the worst leaking one or two done initially. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 9, 2005 Not heard of the Speedos leaking like that before. I've had 3 sets on mine and none of them leaked.....I guess you are unlucky?! I had mine refurbed by http://www.pristinealloywheels.co.uk and they were superb, they look new. The cost for 4 was about £230 all in. If you want a mint set of standard wheels I'd say it's definitely worth it, but if they're just 'get you by' wheels, then it's obviously not worth it. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 9, 2005 I've heard of a couple of people hear saying they have slow leaks due to corrosion around the inner rim where the tyre is supposed to sit. My old set included. But - I haven't heard of anyone who actually tested it in a bucket of water .. Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted August 9, 2005 You might not need them reburbing. You can take the tyre off, rub the part of the wheel that is leaking with really fine emery paper or use a fine wire brush. This will ensure a good seal. It could be the adhesive left over from a previous tyre that was fitted which wasn't removed when your current tyres were fitted. Quote Share this post Link to post Share on other sites
craigowl 0 Posted August 9, 2005 dr_mat said I haven't heard of anyone who actually tested it in a bucket of water .. What size are your buckets ffs?! Didnt mention bucket. :roll: I should not have to be telling a qualified doctor to reread the post carefully. :wink: Quote Share this post Link to post Share on other sites
vr6storm 0 Posted August 9, 2005 should you not have BBS solitudes on yer Storm craigowl :wink: :?: :?: :wink: Quote Share this post Link to post Share on other sites
craigowl 0 Posted August 9, 2005 vr6storm said should you not have BBS solitudes on yer Storm craigowl Silly me. Well spotted! Old age, you know. kev - Clearly one has to expect the added extra with the Storm - leaky Solitudes, as opposed to the inferior non-leaky Speedlines! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 9, 2005 dr_mat said I haven't heard of anyone who actually tested it in a bucket of water .. What size are your buckets ffs?! Didnt mention bucket. :roll: I should not have to be telling a qualified doctor to reread the post carefully. :wink: LOL, and your speedlines^wsolitudes are immune from an attack of pedantry I assume.. ;) Anyway, most tyre places DO have a big wheel-sized bucket to look for leaks. And does it really matter!! Quote Share this post Link to post Share on other sites
craigowl 0 Posted August 9, 2005 dr_mat said And does it really matter!! To all pedants, yes, absolutely! :wink: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 9, 2005 If they look like they need a refurb then go fo it otherwise I'd get the tyres off the rims and clean the inner rim up or try ultraseal maybe? Quote Share this post Link to post Share on other sites
craigowl 0 Posted August 9, 2005 supercharged said try ultraseal maybe? Ive got thingmyseal [pinky American goo - about £50 for 4 C wheels) already in. Clearly, I am not going to recommend it to anyone now, though, the blurb convinced me it was a good buy. Quote Share this post Link to post Share on other sites
pbradley98 0 Posted January 22, 2006 Had the same problem of leaky rims with mine - took it to a tyre shop and cost £24 for two wheels to grind down the inside of the rims and get rid of the corrosion etc and refit / balance the tyres - been fine since... Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted January 22, 2006 also tyre places can just slap some black goo in there that seals the rim. Quote Share this post Link to post Share on other sites
RW1 0 Posted January 22, 2006 The cost for 4 was about £230 all in. Kev, thats a bare cost??? It cost me £295 including tyres off, tyres on at the local pick up point last year and despatch/return from Pristine for a set of 14" wheels. Chris very slow leaks where tyre meets rim Looks like the clear lacquer coat has perished. Common on painted alloys with age. Matter of regular checking/inflating v refurbishment. rub the part of the wheel that is leaking with really fine emery paper or use a fine wire brush That will break the air seal of the laquer on speedlines or solitudes and many other VW painted alloy wheels as the alloy metal is air porous. That's with they eventually start leaking with time as the lacquer coat perishes. . Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 23, 2006 The cost for 4 was about £230 all in. Kev, thats a bare cost??? It cost me £295 including tyres off, tyres on at the local pick up point last year and despatch/return from Pristine for a set of 14" wheels. Yeah just gave them 4 bare wheels, which they collected from work and sent back 3 days later. Quote Share this post Link to post Share on other sites
DanA 0 Posted January 23, 2006 I've got the same problem with 3 of my tyres, very annoying pumping up the tyres every week!! Pretty sure its leaking from the rims. Quote Share this post Link to post Share on other sites
