mbradbrook 0 Posted August 12, 2005 Had an MoT done on the VR6 a month or so ago. The car passed with flying colours but the tester said that by front left brake was binding slightly. Indeed, after i'd been on a longish drive and felt the wheel, it was very hot. Anyway, i stripped the brake carrier , took out the pads, cleaned up the pad guides and greased everything with cooper grease. This seemed to stop the binding but after a month it has come back. Do you think i just didn't clean up the guides well enough or do you think i have a knackered bearing? Any advise greatly appreciated. Matt '95 Classic Green VR6 Quote Share this post Link to post Share on other sites
2cc 0 Posted August 14, 2005 I know it's just been MOT'd, but how thin are your pads? If they are well down then you may have a piston seal hanging up on the outer end of the caliper pot and not returning properly, as there can be some corrosion there. Quote Share this post Link to post Share on other sites
