flusted 0 Posted September 6, 2006 4 wires 1 is feed wire to ecu-purple on rado plug 1st pin 1 is shielded earth-black 2nd pin 1 is earth-brown 3rd pin 1 is ignition live-red pin 4th pin 1-2-3-4 Quote Share this post Link to post Share on other sites
DUB 0 Posted September 7, 2006 4 wires 1 is feed wire to ecu-purple on rado plug 1st pin 1 is shielded earth-black 2nd pin 1 is earth-brown 3rd pin 1 is ignition live-red pin 4th pin 1-2-3-4 Flust will this make any difference if I dont have a lambda anyway de to de-cat? I'm well :? Quote Share this post Link to post Share on other sites
DUB 0 Posted September 7, 2006 Adie - just tried the above ............................... nothing - tried the other holding switch thing in and ......................................... yes you gessed it nothing, do you think there could be anything else thats making this happen? I'm fecked if I can work it out gunna try flushing the ISV through with cleaner and then chucking some injector cleaner through - and feck it gun the t1t's off it - any help gladly welcome - from anyone :wink: :cry: Quote Share this post Link to post Share on other sites
flusted 0 Posted September 7, 2006 you need to tape the switch shut and unplug the lambda and leave it like it,then go for a drive Quote Share this post Link to post Share on other sites
g60griff 0 Posted September 7, 2006 what is the problem if the car runs fine when you do this, i aint tried it yet like. and also my plug was well shagged so its been done away with when i had the charger done at jabba, does it matter which way round the earth wires are? Quote Share this post Link to post Share on other sites
DUB 0 Posted September 8, 2006 you need to tape the switch shut and unplug the lambda and leave it like it,then go for a drive :) Yeah just done this and took it for a rip past VW Bristol's front door - so what have I done? :? its still not right but made me feel a little better just cause it didn't blow up! :lol: so what does tapeing the switch up achive? :?: is it telling the ECU that the engine is flat out? how does that help!!!!?? pulled that plug off {even though 2 of the wires were hangin off anyway} :oops: but what does that achive? and the problem is its still got a miss fire of some kind on idle!!!!? :x played with the idle screw {which was wound all the way out} :oops: which made no difference - what does that mean or do ??? sorry for all the questions - just Adie by the looks at what you've done to yours you'll know alot and how to resolve these f'in problems that {WE} are havin :wink: an it aint no fun when I cant fly like I used to Quote Share this post Link to post Share on other sites
g60griff 0 Posted September 10, 2006 just did this but i left my lambda wired up. it went like a beast and didnt miss a beat. the problem i got was that the idle went up and down really quickly like i was just blipping the throttle a little bit. so what does this show, my wot switch is fecked? Quote Share this post Link to post Share on other sites
