lukeage 0 Posted August 14, 2005 Hi All, Just went to view a vr6 and noted the following: When turning on the ignition (the power phase before you fire it) the abs light would flick for about 2-4 secs and a load of fast bleeps would emit. Also noted that there was no phump / pulse when holding my foot on the brake. What do you guys reackon? Quote Share this post Link to post Share on other sites
The Leningrad Cowboy 0 Posted August 14, 2005 As far as I understand, if the ABS has any faults, it will fail safe, i.e. off, so that it doesn't try and use any dodgy components. Did the light stay on? You can get more detail from the VAG-COM if you're otherwise serious, and there's anyone nearby willing to lend it. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 14, 2005 I think the bleeps were coming from the stereo or imobiliser... The ABS sytem has no audio output. Quote Share this post Link to post Share on other sites
stevemac 0 Posted August 14, 2005 ABS light coming on for a few seconds when the ignition is turned on is normal. The car checks the ABS system (light on) & if the system checks out okay, the light goes out again. If the ABS light stays on - there's a problem of some kind. Quote Share this post Link to post Share on other sites
lukeage 0 Posted August 14, 2005 Maybe it was ok - the light did go out as normal - but prior to that there would be a fast immitent type flash- not sure where the bleeps came from? Maybe all the gurning and dancing round in field off the a4 is having its flash backs :) There is normally a pulse felt through the pedal though i am right? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 14, 2005 There's no ABS pulse through the pedal until you drive away and hit 10kph, when it runs through the valve self-tests. Anything else that happens is a figment of your imagination... Quote Share this post Link to post Share on other sites
VR6 0 Posted August 14, 2005 I get a pulse through the brake pedal when starting the car. And it's not my imagination either :) Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted August 14, 2005 I get a pulse through the brake pedal when starting the car. And it's not my imagination either :) i get the same pulse aswell..i thought it was the abs setting up Quote Share this post Link to post Share on other sites
dinkus 10 Posted August 14, 2005 I get the pulse on start-up to... ;) Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 14, 2005 You talking about the push from the brake vacuum assist coming in when you start the engine? Or an ABS pump pulse? Afaik (and I didn't design it mind), the ABS doesn't operate any valves at all until the 10kph self test. Quote Share this post Link to post Share on other sites
2cc 0 Posted August 14, 2005 It sounds as if its OK as the lamp initially flashes and then goes out. Other than vagcom checking, the easy way to test it is drive the car and brake hard. If the wheels lock up then it's not working. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 15, 2005 When you turn the ignition to stage 2, the ABS system builts up pressure and checks sensors on both circuits (hence the light flashing twice) Quote Share this post Link to post Share on other sites
Claret Badger 0 Posted August 15, 2005 I get the pulse on start-up to... ;) me too Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 15, 2005 Thrash her like a ginger stepchild PMSL!!! Quote Share this post Link to post Share on other sites
Claret Badger 0 Posted August 15, 2005 PMSL!!! I aim to please :2gunfire: Quote Share this post Link to post Share on other sites
