jhanlon 0 Posted August 15, 2005 Anyone have any advice re leaking radiators? My coolant leak has been traced to a hole in the radiator when pressure tested. Having spent a fortune getting car up to date I only want to replace it if this really is the only option (quoted £200 fitted). What about Radweld? Or something similar? I don't want to compromise any part of the cooling system if it's not up to the job. Quote Share this post Link to post Share on other sites
vr6storm 0 Posted August 15, 2005 just bite the bullet and get a new radiator.................radweld might react with yer coolant if its still G11 Quote Share this post Link to post Share on other sites
VR6 0 Posted August 15, 2005 Yeah snap - just replace it. Radweld will never be a permanent fix and can potentially lead to problems as well. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 15, 2005 Radweld is what you put in cars to get them through the next 2 months when you're trying to sell the car. Ahem .. if you happen to be an east end car trader that is. It's no more a long term solution than sticking plasters. Why do a bodge job when it sounds like you're serious about the car? As a side note, it appears someone radwelded my radiator up about 4 years ago (the radiator was then replaced by the car's next owner), and despite numerous coolant flushes, the coolant still goes nasty brown colour within two days of fitting. Not good. Quote Share this post Link to post Share on other sites
jhanlon 0 Posted August 15, 2005 cheers guys - a very quick and resounding thumbs down for Radweld then. Someone has offered to solder it for me but I can't see that being any better and they want me to bring it to 'em. New rad it is then. Quote breaks down at £140 for the part plus an hour's labour. Stealers of course want more. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted August 15, 2005 i did work experiance once at a radiator repair company,if its done right then it should be ok Quote Share this post Link to post Share on other sites
.Rich. 0 Posted August 15, 2005 buy one from your local scrappy and fit it yourself. Nice and cheap, plus they usually have a 1year guarentee so they will swap it if its broken. Quote Share this post Link to post Share on other sites
