Aus
Where would I find the TPS and MAF
Hi, in really easy to understand English/directions (I'm anyhthing but an expert!), where would I find the TPS and MAF sensor???
Many thanks
Which car do you have mate?
MAF is a cylinder thing about 10cm long and 5cm diameter, with a plug on it. It'll be just after the air box.
No idea on TPS tho...
In that case, the MAF is on the top left corner of the engine bay as you look at it from the front of the car :)
The throttle in the middle and slightly to the right at the top of the engine, just behind the pointy type bit...
OK TPS as Kev says is on the side of the throttle body. Wheres the throttle body, well about left of centre from the back of the engine bay where you should be able to see a cable running towards the ground. That the cam that actually move the buttergly in the throttle. The TPS is a black rectangular box on the body to the left of the cable. It has a three wire connector running to it.
Hope that hasnt confused you more!!!!
Do VRs actually have a TPS?
yup, sure do. I've tested mine before to check it was behaving itself.
T.
Alright Timo, long time no see?
I was P'ing about in the same vain as those dossers above (Dinkus and Supercharged), of course the VR has a TPS :wink:
Did you know there are 4 types of TPS for the 2.9 and 2.8 engines?!!
Sorry about that, didn't really read the rest of the posts.
It has been a while, dont get much chance these days to get on here and post. Too busy developing myself into Robocop. 8)
Training hard on my new career at the minute :?
PC T.
