-Neil- 0 Posted August 20, 2005 When ive had the engine running, then turn the car off and take the keys out, and i put my side lights on, then use the dimmer switch, it dims the dash lights but also my actual blower fan, like if the dim is on low, the blower wont be on, as soon as i turn the dimmer switch the blower works. Also before ive started the car and i turn the dimmer switch without headlights on it dims the ring around the headlight switch! Ive been thinking it might be something to do with my alarm, as its when the car is started or imboliser is on or off etc? Can anyone help? Neil Quote Share this post Link to post Share on other sites
StormVR6 0 Posted August 20, 2005 Have you had a new alarm fitted recently? Quote Share this post Link to post Share on other sites
g60griff 0 Posted August 20, 2005 i had a polo before the rado and if i put the blower on full with the headlights on without the key in the ignition nothing much would happen apart from the lights been on, but if i put full beem on the blowers come on. i tried it with the rado and it too does it. does anyone elses? sorry if we are going off topic. Quote Share this post Link to post Share on other sites
-Neil- 0 Posted August 20, 2005 i havent had one fitted myself but a CAT1 one was fitted by the previous owner. Quote Share this post Link to post Share on other sites
StormVR6 0 Posted August 20, 2005 It's only that some alarm systems are fitted very badly (mine was!) and can affect many, many things. Mine had a full monty Clifford fitted by the previous owner, and yes it has taken the car over completely, it does what it likes, when it likes! Behind my dash it looks like a fecking network install, wires and boxes everywhere. Trouble is it would cost more to have it removed than have a new one fitted :lol: Quote Share this post Link to post Share on other sites
randal 0 Posted August 20, 2005 I seem to remember in my polo, if I held the main beams with the ignition off - the fan worked. :scratch: Quote Share this post Link to post Share on other sites
g60cc 0 Posted August 20, 2005 i have same problem when lights on with no key if you pull full beam fan comes on t bought new ind arm from vw it did the same again , elec mate looked at it and said that the leads about 6 in a row from the colom had a live circut IE it was running power to that erea could not understand why. Quote Share this post Link to post Share on other sites
-Neil- 0 Posted August 23, 2005 Ive found something else out, if i have the side lights on, without keys in, and the dimmer switch controls the light ring on the siwtch, if i then press(wobble) in the control on the heater blower, this then makes the dash lights come on which i can then dim with the dimmer switch, so its obviously a lose connection behind the heater blower control! Quote Share this post Link to post Share on other sites
